UM0794: GSM interface
‎2011-09-23 4:45 PM
I read previous threads about source code. But how can i find source code related with UM0794: GSM interface?... Is there any link ? Should we contact local distributor for this? if it is so, why ?
Thanks in advance Best Regards #gsm-stm32 #unavailable-resources #unavailable-resources #unavailable-resources #unavailable-resources- Mark as New
‎2011-09-24 1:40 AM
Well a quick google of UM0794: GSM interface leads to this
http://www.stmicroelectronics.com.cn/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/USER_MANUAL/CD00248834.pdf- Mark as New
‎2011-09-24 1:41 AM
''I read previous threads about source code.''
You mean these:
https://my.st.com/public/STe2ecommunities/mcu/Tags.aspx?tags=unavailable
resources ''Is there any link?'' As discussed in those threads - apparently not! ''Should we contact local distributor for this?'' As discussed in those threads - apparently yes! ''if it is so, why ?'' Thatremains a complete mystery!What on earth are ST playing at here?
Edit
: Sorry, the link above doesn't work - try:A complex system designed from scratch never works and cannot be patched up to make it work.
‎2011-09-24 1:45 AM
''Well a quick google of UM0794: GSM interface leads to this
http://www.stmicroelectronics.com.cn/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/USER_MANUAL/CD00248834.pdf''; But that's not the code - is it?
That's just a PDF document!
It tells you that code exists but gives no information on how to obtain it!A complex system designed from scratch never works and cannot be patched up to make it work.
‎2011-09-24 10:02 AM
Beats me! Perhaps you should ask here:/b2dac913
‎2014-04-04 2:21 AM
Could you able to find the source code for GSM Library for STM32 ?If so could you please share it ?Thank you in advanceRegards,Praveen- Mark as New
‎2014-05-22 9:14 AM
Please contact your distributor/FAE to get the firmware. The PDF file is availablehttp://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/CD00248834.pdf
. -Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
‎2014-05-22 11:48 AM
''Please contact your distributor/FAE to get the firmware''
So how about answering the question:
WHY??
