2011-09-23 04:45 PM
I read previous threads about source code. But how can i find source code related with UM0794: GSM interface?... Is there any link ? Should we contact local distributor for this? if it is so, why ?
Thanks in advance Best Regards #gsm-stm32 #unavailable-resources #unavailable-resources #unavailable-resources #unavailable-resources2011-09-24 01:40 AM
Well a quick google of UM0794: GSM interface leads to this
http://www.stmicroelectronics.com.cn/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/USER_MANUAL/CD00248834.pdf2011-09-24 01:41 AM
''I read previous threads about source code.''
You mean these:
https://my.st.com/public/STe2ecommunities/mcu/Tags.aspx?tags=unavailable
resources ''Is there any link?'' As discussed in those threads - apparently not! ''Should we contact local distributor for this?'' As discussed in those threads - apparently yes! ''if it is so, why ?'' Thatremains a complete mystery!What on earth are ST playing at here?
Edit
: Sorry, the link above doesn't work - try:2011-09-24 01:45 AM
''Well a quick google of UM0794: GSM interface leads to this
http://www.stmicroelectronics.com.cn/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/USER_MANUAL/CD00248834.pdf''; But that's not the code - is it?
That's just a PDF document!
It tells you that code exists but gives no information on how to obtain it!2011-09-24 10:02 AM
Beats me! Perhaps you should ask here:/b2dac913
2014-04-04 02:21 AM
Could you able to find the source code for GSM Library for STM32 ?If so could you please share it ?Thank you in advanceRegards,Praveen2014-05-22 09:14 AM
Please contact your distributor/FAE to get the firmware. The PDF file is availablehttp://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/CD00248834.pdf
. -Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
2014-05-22 11:48 AM
''Please contact your distributor/FAE to get the firmware''
So how about answering the question:
WHY??
