UM0794: GSM interface
irmakci
Posted on September 24, 2011 at 01:45
I read previous threads about source code. But how can i find source code related with UM0794: GSM interface?... Is there any link ? Should we contact local distributor for this? if it is so, why ?
Thanks in advance
Best Regards
#gsm-stm32 #unavailable-resources #unavailable-resources #unavailable-resources #unavailable-resources
7 REPLIES 7
trevor23
Posted on September 24, 2011 at 10:40
Well a quick google of UM0794: GSM interface leads to this
http://www.stmicroelectronics.com.cn/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/USER_MANUAL/CD00248834.pdf
Posted on September 24, 2011 at 10:41
''I read previous threads about source code.''
You mean these:
https://my.st.com/public/STe2ecommunities/mcu/Tags.aspx?tags=unavailable
resources
''Is there any link?''
As discussed in those threads - apparently not!
''Should we contact local distributor for this?''
As discussed in those threads - apparently yes!
''if it is so, why ?''
Thatremains a complete mystery!
What on earth are ST playing at here?
Edit
: Sorry, the link above doesn't work - try:
http://bit.ly/rl8dho
Posted on September 24, 2011 at 10:45
''Well a quick google of UM0794: GSM interface leads to this
http://www.stmicroelectronics.com.cn/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/USER_MANUAL/CD00248834.pdf'';
But that's not the code - is it?
That's just a PDF document!
It tells you that code exists but gives no information on how to obtain it!
Posted on September 24, 2011 at 19:02
Beats me!
Perhaps you should ask here:
/b2dac913
contact23
Posted on April 04, 2014 at 11:21
Could you able to find the source code for GSM Library for STM32 ?
If so could you please share it ?
Thank you in advance
Praveen
Amel NASRI
Posted on May 22, 2014 at 18:14
Please contact your distributor/FAE to get the firmware. The PDF file is available
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/CD00248834.pdf
-Mayla-
Posted on May 22, 2014 at 20:48
''Please contact your distributor/FAE to get the firmware''
So how about answering the question:
WHY??
