OpenOCD remote session fails due to verification
‎2024-06-17 3:02 PM
for a remote dev environment I need to connect to the on-board stlink remotely.
when trying to connect I get this error:
I already tried this forum solution
but the issue persists. Any hint?
STM32WL series
‎2024-06-18 3:07 AM
Hello @ltoso.1
For such an issue, I suggest you to:
- Upgrade to the Latest STM32CubeIDE Version.
- Use the Latest ST-LINK GDB Server.
- Check for the ST-LINK Firmware Updates.
- Verify Connection and Proxy Settings are correct.
Best Regards.
STTwo-32
‎2024-06-18 3:38 AM
Hello STTwo-32,
thanks for your reply.
I am using the last update from repository for openocd on my raspberry pi.
The st-link I am trying to connect to is the embedded one on the WL55 nucleo board.
CubeIDE is fully updated
I also changed the expected-id in stm32wlx.cfg from openocd as suggeste in the linked post.
any other hint?
any other hint I should check?
‎2024-06-28 8:15 AM
What is exactly the Setup that you are using?
Best Regards.
STTwo-32
