2024-08-28 8:03 AM
I just try to get a NUCLEO-WB09KE board running.
Unfortunately CubeMX (6.12.0) generates HAL files with a pattern of stm32wb0x_hal...,h but the include paths are stm32wb00x_hal (one more zero!)...
Also in CubeIDE EXTI_HandleTypeDef is not found when compiling.
Best regards,
Achim
2024-09-03 3:25 AM
Hello @AWack
Thank you for reporting.
Actually, this issue has been reported internally to Dev team for correction (under internal ticket number 190038 ) and it will be fixed ASAP.
Thank you!
Mahmoud
2024-08-28 9:55 AM - edited 2024-08-28 10:01 AM
Hello @AWack ,
First let me thank you for posting.
Your request is under investigation, and I will get back to you ASAP.
Thanks.
Mahmoud
2024-08-29 6:57 AM
Hello @AWack ,
I am not able to reproduce your issue by creating a project with NUCLEO-WB09KE board.
I suggest that you provide your ioc.File.
Thanks.
Mahmoud
2024-08-29 7:00 AM
2024-09-03 3:25 AM
Hello @AWack
Thank you!
Mahmoud
