2021-11-04 12:28 AM
Hello, i'm using the NUCLEO-WL55JC board.
I am using the LoRaWAN_End_Node example which works fine. However I reach an operating current of around 50mA.
Do you have an idea for a solution?
Have a good day !
2021-11-04 1:04 PM
Hello @LMesn.1 ,
The following features are implemented to reduce the current consumption:
Please refer to this AN5568 "Ultra-low-power features of STM32WL Series microcontrollers", it may be helpful for you.
Imen
2021-11-04 1:04 PM
Hello @LMesn.1 ,
Imen
2021-11-07 1:37 AM
Thank you very much, i will try all of this.
Have a good day.
2021-11-09 12:54 AM
Hello i applied your advice, and i also changed the supply mode and everything is good. Thank you !
