Shati.1
L073RZ with the expansion do not work with tera term
  • July 8, 2021
  • 4 replies
  • 1112 views
Hi, i m working with P-NUCLEO LRWAN2 , the gateway is working good, but the L073RZ with the expansion do not work with tera term and don't send any data
Andrew Neil
It's not intended to work with TeraTerm (or any other terminal) - it is a standalone node.
This is described in the P-NUCLEO-LORWAN2 documentation.
EDIT
See my post of  January 20, 2021 at 12:05 PM in this thread:
https://community.st.com/s/question/0D53W00000DHlVaSAL/i-want-to-get-pnucleolrwan2-gateway-source
Also my post in this thread:
https://community.st.com/s/question/0D53W00000HMBXUSA5/pnucleolrwan2-sensors-node-does-not-respond-to-at-command-through-a-virtual-serial-tera-terminal
(Sorry, this forum doesn't give links to specific posts :pouting_face: )
Hello @Shati.1​ ,
I added this post of @Andrew Neil​ , it contains the fixes proposed by JCOUP.
Hope this helps you !
Imen
Shati.1
Shati.1Author
Thank you for your help
Andrew Neil
Note that these fixes don't make any difference to the fact that the code does not - and is not intended to - give any output to a local terminal
