Dear Sir, we are working on STM32WL series micro-controller and want to know how to do range testing between two STM32WL series micro-controller(firmware/utility) Also, how to establish point to multipoint communication between STM32WL
pthor.1
3 REPLIES 3
Point to point, perhaps look at the Ping Pong examples
STM32Cube_FW_WL_V1.1.0\Projects\NUCLEO-WL55JC\Applications\SubGHz_Phy\SubGHz_Phy_PingPong
Perhaps use a GPS receiver, transmit a position, map distance vs signal strength.
Evaluate different antenna, signal strength settings, modulation settings / spreading factors.
pthor.1
Dear Sir,
Thank you for your reply
We want to configure STM32WL series micro-controller as Gateway can you please share the references /firmware source. We found source code for STM32WL as End node but, unable to get source code for STM32WL as Gateway. Please, let me know suggestions
Javier1
Principal
>>point multipoint
read about "advertising packets in BLE" or "simultaneous connections".
Available for consulting/freelancing , hit me up in https://github.com/javiBajoCero
