2024-05-07 08:35 AM
hi,
Im using my own costum board with a STM32WBA52CG on it. When I'm nog using the RF my code is working perfectly. When I activate the RF in the STM32CubeIDE, my code is stuck in PeriphCommonClock_Config();
More specifically in the following code:
I already checked my HSE crystal and I'm getting 32 MHz out. So what could be wrong? because without the RF I'm not able to use BLE..
Thanks in advance!
Kind regards,
Mats
2024-06-02 10:06 AM
I did not attach the antenna yet, thats why it got stuck on that line!
2024-06-02 09:53 AM
Hello @matsmort
Could you share your .ioc file.
Best Regards.
STTwo-32
2024-06-02 09:54 AM
it is already solved!
kind regards,
mats
2024-06-02 10:02 AM
Happy to know that. Could you please share the solution. That may help other users.
Best Regards.
STTwo-32
2024-06-02 10:06 AM
