ADC error
Ranjeet Singh
when i generate the adc based code then it show the error without doing anything in the main  code
reason is this that there is no driver of adc ,so copy from another folder and paste in this code,so now working
6 REPLIES 6
Issamos
Lead II
Hello @Ranjeet Singh
Can you add the code you are using, your firmware version and your CubeIDE and CubeMX version to make it easier to find the problem.
Best regards.
II
Ranjeet Singh
code is bydefault generated
I suggest you change the directory file and regenerate the code.
Best regards.
II
Issamos
Lead II
If your question is answered please check the solution as best answer to be diffused to everyone.
Best regards.
II
i have another problem ,live debugging not work, it say target not found
