About STM32WL55
Son, Dong-Seong
Hi.
I am using STM32WL55 for FSK communication.
Firmware version is STM32Cube_FW_WL_V1.3.0.
In the past, version 1.1.0 was used, but version 1.3.0 has changed a lot.
So I'm not sure how to set it up.
​First of all, I want to set SUBGHZ_PHY, but the Enable check box is disabled as follows.
_legacyfs_online_stmicro_images_0693W00000bhpvMQAQ.pngAnd files related to SUBGHZ_PHY and Radio are not visible after [Generate Code].
Could you let me know why it is disabled and how I can use it?​
Please give me a procedure or method on how to set up and use FSK.
Thank you.​
Foued_KH
Hello ,
For the SUBGHZ​_PHY in Middleware and Software :
For dual core you need to Activate the IPCC and the SUBGHZ.
Foued
6 REPLIES 6
Foued_KH
Hello @SOn, Dong-Seong​ ,
Make sure that you are using the latest version of STM32CubeMX 6.8.0 .
If I select the SUBGHZ peripheral under the Connectivity category, I can check the box next to Activated.
Foued
Hi.
It is SUBGHZ​_PHY in Middleware and Software, not in Connectivity.
I want to enable SUBGHZ_PHY in Middleware and Software
Foued_KH
Hello ,
Foued
malarab
Senior II
hi @SOn, Dong-Seong​ ,
to use the SUBGHZ_PHY driver, you need first to enable the SUBGHZ peripheral.
you also need to enable RTC to configure timer server.
Oh
When I activated IPCC, I was able to enable SUBGHZ_PHY.
I resolved it
Thank you so much
If this solves your problem, please mark my answer as "Best Answer" by clicking on the "Select as Best" button, this can be helpful for Community users to find this solution faster.
