2020-04-13 2:16 PM
The article in the following link no longer exists (frustrating) and I'd like to refer to the info previously found there.
https://touchgfx.zendesk.com/hc/en-us/articles/203642951-MCUs-without-TFT-controller
I did search support.touchgfx.com and did not find it.
Apparently one must copy/paste articles because they will disappear?
2020-04-14 6:36 AM
https://support.touchgfx.com/docs/development/touchgfx-hal-development/scenarios/scenarios-fmc
This article is about SPI/FMC. You'll also be linked to this article from the TouchGFX Generator "Custom Display Interface". I will go through it again to see if it's apparent enough that this is for MCUs with no TFT controller. It should be there somewhere, but might not be apparent enough,.
/Martin
2020-04-14 6:36 AM
/Martin
