What to do, I have broken the display of X-NUCLEO-GFX01M2?
Lemuel
The TFT dsiplay was cracked, can I but the display only from ST ?
Yoann KLEIN
Hello @Lemuel​,
Of course you can buy it separately, here for example.
Also, that question doesn't concern TouchGFX, so please try to change or add more tags next time you are creating a new post please ��
Hope that it helped you,
/Yoann
Yoann KLEIN
4 REPLIES 4
Yoann KLEIN
Hello @Lemuel​,
/Yoann
Yoann KLEIN
Peter BENSCH
The display can also be bought separately from Mouser or Digikey, for example, but it is only slightly cheaper than the complete X-NUCLEO-GFX01M2. That's why @Yoann KLEIN​ suggested the URL to buy a complete X-NUCLEO, which is definitely the easiest option.
Good luck!
/Peter
Lemuel
Peter and Yoann,
Thanks for your advice.
Yes, the screen from Mouser and Digikey is quite expensive either, I can't afford that.��
May be I try my luck in taobao and alibaba too.
Best regards,
Fai
DISPLAYTECH DT022CTFT
https://www.seacomp.com/product/2-2-inch-tft-lcd-dt022ctft
