Weird behavior when animation
vtunr
I'm working with TouchGFX with STM32F746BG, and I have an issue when there is animation.
You can find a video of the problem here : https://youtu.be/X-D-NkGCN5k
I also have the same issue when I add an animation between screen.
At the beginning I was working without TouchGFX (and without external ram), playing with LTDC layer, moving and everything and I no issue.
Any idea where this could come from ?
Tony
EDIT: Updated video to the right one
13 REPLIES 13
Would be great to have a video of current behavior, thanks!
/Martin
@Martin KJELDSEN​ So I made three videos :
* With lockDMAToFrontPorch(true) and logo 1 : https://www.youtube.com/watch?v=SIBAnAXJJx8&feature=youtu.be
* With lockDMAToFrontPorch(true) and logo 2 : https://www.youtube.com/watch?v=ZQFIjuRJzN0&feature=youtu.be
* With lockDMAToFrontPorch(false) and logo 1 : https://www.youtube.com/watch?v=fteLrblcx_A&feature=youtu.be
So you can see :
* lockDMAToFrontPorch(true) improves things, but it's not perfect
* Given the image we load, we have different behavior, as TouchGFX logo has no issue
* Transition between screens is not clean
* Sliding the slider is also not clean
logo 1 : https://imgur.com/G2k3Ne9
logo 2 : https://imgur.com/yrsQu5s
Let me know if you need more information.
Tony
@Martin KJELDSEN​ Any ideas where this could come from ?
Tony
vtunr
Switched to 16bits, working fine now.
Also some improvements come from :
  • Putting framebuffer in different memory bank
  • For 24 bit, setting 832 pixel wide
They are explained : https://www.st.com/content/ccc/resource/technical/document/application_note/group0/25/ca/f9/b4/ae/fc/4e/1e/DM00287603/files/DM00287603.pdf/jcr:content/translations/en.DM00287603.pdf (4.5.2, 4.5.3)
