Weird behavior when animation
‎2019-10-21 9:44 AM
I'm working with TouchGFX with STM32F746BG, and I have an issue when there is animation.
You can find a video of the problem here : https://youtu.be/X-D-NkGCN5k
I also have the same issue when I add an animation between screen.
At the beginning I was working without TouchGFX (and without external ram), playing with LTDC layer, moving and everything and I no issue.
Any idea where this could come from ?
Tony
EDIT: Updated video to the right one
- Labels:
STM32F7 Series
TouchGFX
‎2019-11-04 2:57 AM
Would be great to have a video of current behavior, thanks!
/Martin
‎2019-11-04 6:58 AM
@Martin KJELDSEN​ So I made three videos :
* With lockDMAToFrontPorch(true) and logo 1 : https://www.youtube.com/watch?v=SIBAnAXJJx8&feature=youtu.be
* With lockDMAToFrontPorch(true) and logo 2 : https://www.youtube.com/watch?v=ZQFIjuRJzN0&feature=youtu.be
* With lockDMAToFrontPorch(false) and logo 1 : https://www.youtube.com/watch?v=fteLrblcx_A&feature=youtu.be
So you can see :
* lockDMAToFrontPorch(true) improves things, but it's not perfect
* Given the image we load, we have different behavior, as TouchGFX logo has no issue
* Transition between screens is not clean
* Sliding the slider is also not clean
logo 1 : https://imgur.com/G2k3Ne9
logo 2 : https://imgur.com/yrsQu5s
Let me know if you need more information.
Tony
‎2019-11-11 12:55 AM
@Martin KJELDSEN​ Any ideas where this could come from ?
Tony
‎2019-12-05 7:35 AM
Switched to 16bits, working fine now.
Also some improvements come from :
- Putting framebuffer in different memory bank
- For 24 bit, setting 832 pixel wide
They are explained : https://www.st.com/content/ccc/resource/technical/document/application_note/group0/25/ca/f9/b4/ae/fc/4e/1e/DM00287603/files/DM00287603.pdf/jcr:content/translations/en.DM00287603.pdf (4.5.2, 4.5.3)
- « Previous
- 1
- 2
- Next »
