Tutorial 1 Run target error
JKim.1006
I bought a stm32H747I DISCO for using TouchGFX.
Now I'm following steps of tutorial 1, but Run target is not working.
I will attach Detatiled Log.
Thank you.
Run Target
  Generate
    Done
  Generate Assets
    make -f simulator/gcc/Makefile assets -j8
    Converting images
    Done
  Post Generate
    touchgfx update_project --project-file=simulator/msvs/Application.vcxproj && touchgfx update_project --project-file=../EWARM/TouchGFX.ewp
    Done
  Compile
    make -f ../gcc/Makefile -j8
    STM32CubeProgrammer is placed in Program Files
    Converting images
    Linking TouchGFX/build/bin/target.elf
    Producing additional output formats...
     target.hex  - Combined internal+external hex
     intflash.elf - Internal flash, elf debug
     intflash.hex - Internal flash, hex
     extflash.bin - External flash, binary
    Done
  Flash
    make -f ../gcc/Makefile -j8 flash
    Converting images
    /usr/bin/sh: C:\Program Files\STMicroelectronics\STM32Cube\STM32CubeProgrammer\bin\STM32_Programmer_CLI.exe: No such file or directory
    gcc/Makefile:334: recipe for target '_extflash_' failed
    make[1]: *** [_extflash_] Error 127
    make: *** [flash] Error 2
    ../gcc/Makefile:50: recipe for target 'flash' failed
    Failed
  Failed
Martin KJELDSEN
Chief III
You need to install STM32CubeProgrammer.
/Martin
7 REPLIES 7
Martin KJELDSEN
Chief III
/Martin
DMeis.1
Run Target
    Generate
        Done
    Generate Assets
        make -f simulator/gcc/Makefile assets -j10
        Converting images
        Done
    Post Generate
        touchgfx update_project --project-file=../EWARM/STM32F7508_DISCO.ewp --gui-group-name=Application/User/TouchGFX/gui --generated-group-name=Application/User/TouchGFX/generated && touchgfx update_project --project-file=simulator/msvs/Application.vcxproj
        Done
    Compile
        Converting images
        Done
    Flash
        Converting images
        /usr/bin/sh: C:\Program Files (x86)\STMicroelectronics\STM32 ST-LINK Utility\ST-LINK Utility\ST-LINK_CLI.exe: No such file or directory
        gcc/Makefile:311: recipe for target '_flash_' failed
        make[1]: *** [_flash_] Error 127
        Failed
    Failed
I am getting a similar error, i don't know how to install STM32 ST-Link
Great. We've considered how to get around users having this issue, maybe bundling the tools and installing them as pre-requisites when installing designer.
OK so now I am getting this error...
    Flash
        make -f target/gcc/Makefile -j8 flash
        make: target/gcc/Makefile: No such file or directory
        make: *** No rule to make target 'target/gcc/Makefile'.  Stop.
        Failed
    Failed
Check target/gcc/Makefile - Do you have that file?
yeah the solution here was I went in configure-> build and changed the Target Flash from
to
