2021-03-19 03:51 AM
I need to create a graph in TouchGFX where the points on that graph will be read from a .csv file. In that first moment I will use only the TouchGFX simulator. Would you have an example where the simulator can read data from a csv file and create the graph?
2021-03-21 10:40 AM
I mean you can use FrontendApplication.cpp file for this load .
