TouchGFX not downloading
Ricko
Senior III
I tried downloading TouchGFX but even after following the instructions and using the same browser and validating the email and using the same browser, it displays the message below. Where else can I download the latest TouchGFX from?
Also:
- what is the difference between X-CUBE-TOUCHGFX and X-TOUCHGFX-MPU (second screenshot)
- does the latest version include TouchGFX, TouchGFX Designer and all required libraries and code generator in one single package/download?
Thank you
mÆŽALLEm
The difference between X-CUBE-TOUCHGFX and X-TOUCHGFX-MPU the first one is for the MCU and the second one is for MPU.
To my knowledge if you download TouchGFX Designer package is sufficient. CubeMx will be responsible of the library package download. The library package will be normally available under C:\TouchGFX
The designer is under \Utilities\PC_Software\TouchGFXDesigner\
mÆŽALLEm
Thank you @mÆŽALLEm
