TouchGFX 4.17.0 ,"you are not connected to internet" error is showing
SV
when TouchGFX 4.17.0 is opened I'm getting an error stating no internet connectivity even though my laptop is connected to internet . also in the selection of boards I'm not getting any board option .
thanks and regards
sinduja
62 REPLIES 62
MG32
with TouchGFX Designer 4.18, a proxy dialog with username/password appears, but according to my local IT it is not possible to connect with packages.touchgfx.com because SSL certificate has expired.
https://www.ssllabs.com/ssltest/analyze.html?d=packages.touchgfx.com
Can you please renew your certificate?
Thanks.
You are now able to connect to the proxy dialog but still cannot download TBSes and demos ? Could you share your log file again �� ?
Could you open Microsoft Edge before opening TouchGFX Designer to make sure it reaches the server ?
/Romain
yes, I cannot download TBSes and demos.
According to my local IT, our proxy rejects connection to packages.touchgfx.com because SSL certificate has expired.
https://www.ssllabs.com/ssltest/analyze.html?d=packages.touchgfx.com shows "Certificate name mismatch"
Messages from log file (with Edge open):
2021-10-28 10:27:23,180 [1] INFO TouchGFXDesigner.App: Logging configured
2021-10-28 10:27:24,299 [1] ERROR Utils.WebHandling.WebHandler: The remote server returned an error: (407) Proxy Authentication Required.
System.Net.WebException: The remote server returned an error: (407) Proxy Authentication Required.
  at System.Net.HttpWebRequest.GetResponse()
  at System.Net.WebClient.GetWebResponse(WebRequest request)
  at System.Net.WebClient.OpenRead(Uri address)
  at Utils.WebHandling.WebHandler.RequestWithStringResponse(Uri uri)
2021-10-28 10:27:26,000 [1] INFO TouchGFXDesigner.Main.MainWindow: Application started
2021-10-28 10:27:26,001 [1] INFO TouchGFXDesigner.Main.MainWindow: Username: ***
2021-10-28 10:27:26,001 [1] INFO TouchGFXDesigner.Main.MainWindow: Designer version: 4.18.0
2021-10-28 10:27:26,001 [1] INFO TouchGFXDesigner.Main.MainWindow: Designer installation path: C:\TouchGFX\4.18.0\designer
2021-10-28 10:27:26,001 [1] INFO TouchGFXDesigner.Main.MainWindow: Windows version: Microsoft Windows NT 10.0.19042.0
2021-10-28 10:27:26,001 [1] INFO TouchGFXDesigner.Main.MainWindow: Current culture: de-DE
2021-10-28 10:27:26,039 [1] INFO TouchGFXDesigner.Main.MainWindow: Current culture time seperator: :
2021-10-28 10:27:26,039 [1] INFO TouchGFXDesigner.Main.MainWindow: Current culture date seperator: .
2021-10-28 10:27:26,042 [1] INFO TouchGFXDesigner.Main.MainWindow: Installed .NET version(s): v2.0.50727 2.0.50727.4927 SP2v3.0 3.0.30729.4926 SP2v3.5 3.5.30729.4926 SP1v4 (Client 4.8.04084 Full 4.8.04084 ) v4.0 (Client 4.0.0.0 )
2021-10-28 10:27:30,761 [12] ERROR Utils.WebHandling.WebHandler: The remote server returned an error: (407) Proxy Authentication Required.
  at Utils.WebHandling.ServerRequest.GetResponse()
  at Utils.WebHandling.WebHandler.RequestHeadStatusResponse(Uri uri)
2021-10-28 10:50:43,755 [1] DEBUG TouchGFXPackages.Implementation.TouchGFXPackageStream: Filestream opened on C:\TouchGFX\4.18.0\app\packages\Simulator-2.0.0.tpa
2021-10-28 10:50:45,362 [12] ERROR Utils.WebHandling.WebHandler: The remote server returned an error: (409) Conflict.
System.Net.WebException: The remote server returned an error: (409) Conflict.
2021-10-28 10:50:47,047 [12] ERROR Utils.WebHandling.WebHandler: The remote server returned an error: (409) Conflict.
2021-10-28 10:50:48,986 [15] ERROR Utils.WebHandling.WebHandler: The remote server returned an error: (409) Conflict.
2021-10-28 10:50:50,966 [10] ERROR Utils.WebHandling.WebHandler: The remote server returned an error: (409) Conflict.
2021-10-28 10:50:52,614 [1] DEBUG TouchGFXPackages.Implementation.TouchGFXPackageStream: Filestream opened on C:\TouchGFX\4.18.0\app\packages\Simulator-2.0.0.tpa
2021-10-28 10:50:52,799 [1] DEBUG TouchGFXPackages.Implementation.TouchGFXPackageStream: Filestream opened on C:\TouchGFX\4.18.0\app\packages\Simulator-2.0.0.tpa
2021-10-28 10:50:52,817 [1] DEBUG TouchGFXPackages.Implementation.TouchGFXPackageStream: Filestream opened on C:\TouchGFX\4.18.0\app\packages\Simulator-2.0.0.tpa
2021-10-28 10:50:52,954 [10] ERROR Utils.WebHandling.WebHandler: The remote server returned an error: (409) Conflict.
2021-10-28 10:50:53,844 [1] DEBUG TouchGFXPackages.Implementation.TouchGFXPackageStream: Filestream opened on C:\TouchGFX\4.18.0\app\packages\Simulator-2.0.0.tpa
2021-10-28 10:50:53,845 [1] DEBUG TouchGFXPackages.Implementation.TouchGFXPackageStream: Filestream opened on C:\TouchGFX\4.18.0\app\packages\Simulator-2.0.0.tpa
2021-10-28 10:50:53,846 [1] DEBUG TouchGFXPackages.Implementation.TouchGFXPackageStream: Filestream opened on C:\TouchGFX\4.18.0\app\packages\Simulator-2.0.0.tpa
2021-10-28 10:50:53,847 [1] DEBUG TouchGFXPackages.Implementation.TouchGFXPackageStream: Filestream opened on C:\TouchGFX\4.18.0\app\packages\Simulator-2.0.0.tpa
2021-10-28 10:50:53,918 [1] DEBUG TouchGFXPackages.Implementation.TouchGFXPackageStream: Filestream opened on C:\TouchGFX\4.18.0\app\packages\Simulator-2.0.0.tpa
2021-10-28 10:50:55,074 [15] ERROR Utils.WebHandling.WebHandler: The remote server returned an error: (409) Conflict.
2021-10-28 10:50:56,948 [10] ERROR Utils.WebHandling.WebHandler: The remote server returned an error: (409) Conflict.
2021-10-28 10:50:58,956 [10] ERROR Utils.WebHandling.WebHandler: The remote server returned an error: (409) Conflict.
2021-10-28 10:50:59,216 [9] INFO TouchGFXPackages.Implementation.FileDownloader: Take operation was canceled. IsCancellationRequested=True
2021-10-28 10:50:59,233 [1] INFO TouchGFXDesigner.Main.MainWindow: Application closed
Sorry for jumping in. I have the same problem. I don't have to access the internet for our development so far. However, I can't open my project file because the proxy error occurs continuously. My log file is the attached. Could you please tell me how to stop accessing your server.
Are you able to enter your proxy logins ? From the log file it seems you never have.
/Romain
MG32
https://www.ssllabs.com/ssltest/analyze.html?d=packages.touchgfx.com still shows "Certificate name mismatch".
According to my local IT, this is the reason why our Proxy blocks access.
Can you please fix this issue?
Thanks.
Yes you wrote that 3 times �� I have not replied on this as I am waiting for feedback from the Designer team. This is the first time we hear/face this so this confuses us a bit.
/Romain
MTana.1
Yes, I can. This answer is written with same PC and proxy.
I think it takes long time for resolve. I'd like to know how to edit TouchGFX project without proxy access. I don't have to access the internet for our development so far.
If I understood correctly what I was told recently this is not possible with TouchGFX 4.17 and 4.18.0 as the touchgfx.config file in the TouchGFX instalation folder was removed. It should/may be re - introduced back with TouchGFX 4.18.1, if not then TouchGFX 4.19.
For now I can only recommend to use TouchGFX 4.16.1 if you are not able to work with 4.18 even with the tpas I shared.
/Romain
