2021-07-24 12:48 AM
when TouchGFX 4.17.0 is opened I'm getting an error stating no internet connectivity even though my laptop is connected to internet . also in the selection of boards I'm not getting any board option .
thanks and regards
sinduja
2021-10-28 12:00 AM
with TouchGFX Designer 4.18, a proxy dialog with username/password appears, but according to my local IT it is not possible to connect with packages.touchgfx.com because SSL certificate has expired.
https://www.ssllabs.com/ssltest/analyze.html?d=packages.touchgfx.com
Can you please renew your certificate?
Thanks.
2021-10-28 12:24 AM
You are now able to connect to the proxy dialog but still cannot download TBSes and demos ? Could you share your log file again :grinning_face_with_sweat: ?
Could you open Microsoft Edge before opening TouchGFX Designer to make sure it reaches the server ?
/Romain
2021-10-28 02:07 AM
yes, I cannot download TBSes and demos.
According to my local IT, our proxy rejects connection to packages.touchgfx.com because SSL certificate has expired.
https://www.ssllabs.com/ssltest/analyze.html?d=packages.touchgfx.com shows "Certificate name mismatch"
Messages from log file (with Edge open):
2021-10-28 10:27:23,180 [1] INFO TouchGFXDesigner.App: Logging configured
2021-10-28 10:27:24,299 [1] ERROR Utils.WebHandling.WebHandler: The remote server returned an error: (407) Proxy Authentication Required.
System.Net.WebException: The remote server returned an error: (407) Proxy Authentication Required.
at System.Net.HttpWebRequest.GetResponse()
at System.Net.WebClient.GetWebResponse(WebRequest request)
at System.Net.WebClient.OpenRead(Uri address)
at Utils.WebHandling.WebHandler.RequestWithStringResponse(Uri uri)
2021-10-28 10:27:26,000 [1] INFO TouchGFXDesigner.Main.MainWindow: Application started
2021-10-28 10:27:26,001 [1] INFO TouchGFXDesigner.Main.MainWindow: Username: ***
2021-10-28 10:27:26,001 [1] INFO TouchGFXDesigner.Main.MainWindow: Designer version: 4.18.0
2021-10-28 10:27:26,001 [1] INFO TouchGFXDesigner.Main.MainWindow: Designer installation path: C:\TouchGFX\4.18.0\designer
2021-10-28 10:27:26,001 [1] INFO TouchGFXDesigner.Main.MainWindow: Windows version: Microsoft Windows NT 10.0.19042.0
2021-10-28 10:27:26,001 [1] INFO TouchGFXDesigner.Main.MainWindow: Current culture: de-DE
2021-10-28 10:27:26,039 [1] INFO TouchGFXDesigner.Main.MainWindow: Current culture time seperator: :
2021-10-28 10:27:26,039 [1] INFO TouchGFXDesigner.Main.MainWindow: Current culture date seperator: .
2021-10-28 10:27:26,042 [1] INFO TouchGFXDesigner.Main.MainWindow: Installed .NET version(s): v2.0.50727 2.0.50727.4927 SP2v3.0 3.0.30729.4926 SP2v3.5 3.5.30729.4926 SP1v4 (Client 4.8.04084 Full 4.8.04084 ) v4.0 (Client 4.0.0.0 )
2021-10-28 10:27:30,761 [12] ERROR Utils.WebHandling.WebHandler: The remote server returned an error: (407) Proxy Authentication Required.
at Utils.WebHandling.ServerRequest.GetResponse()
at Utils.WebHandling.WebHandler.RequestHeadStatusResponse(Uri uri)
2021-10-28 10:50:43,755 [1] DEBUG TouchGFXPackages.Implementation.TouchGFXPackageStream: Filestream opened on C:\TouchGFX\4.18.0\app\packages\Simulator-2.0.0.tpa
2021-10-28 10:50:45,362 [12] ERROR Utils.WebHandling.WebHandler: The remote server returned an error: (409) Conflict.
System.Net.WebException: The remote server returned an error: (409) Conflict.
2021-10-28 10:50:47,047 [12] ERROR Utils.WebHandling.WebHandler: The remote server returned an error: (409) Conflict.
2021-10-28 10:50:48,986 [15] ERROR Utils.WebHandling.WebHandler: The remote server returned an error: (409) Conflict.
2021-10-28 10:50:50,966 [10] ERROR Utils.WebHandling.WebHandler: The remote server returned an error: (409) Conflict.
2021-10-28 10:50:52,614 [1] DEBUG TouchGFXPackages.Implementation.TouchGFXPackageStream: Filestream opened on C:\TouchGFX\4.18.0\app\packages\Simulator-2.0.0.tpa
2021-10-28 10:50:52,799 [1] DEBUG TouchGFXPackages.Implementation.TouchGFXPackageStream: Filestream opened on C:\TouchGFX\4.18.0\app\packages\Simulator-2.0.0.tpa
2021-10-28 10:50:52,817 [1] DEBUG TouchGFXPackages.Implementation.TouchGFXPackageStream: Filestream opened on C:\TouchGFX\4.18.0\app\packages\Simulator-2.0.0.tpa
2021-10-28 10:50:52,954 [10] ERROR Utils.WebHandling.WebHandler: The remote server returned an error: (409) Conflict.
2021-10-28 10:50:53,844 [1] DEBUG TouchGFXPackages.Implementation.TouchGFXPackageStream: Filestream opened on C:\TouchGFX\4.18.0\app\packages\Simulator-2.0.0.tpa
2021-10-28 10:50:53,845 [1] DEBUG TouchGFXPackages.Implementation.TouchGFXPackageStream: Filestream opened on C:\TouchGFX\4.18.0\app\packages\Simulator-2.0.0.tpa
2021-10-28 10:50:53,846 [1] DEBUG TouchGFXPackages.Implementation.TouchGFXPackageStream: Filestream opened on C:\TouchGFX\4.18.0\app\packages\Simulator-2.0.0.tpa
2021-10-28 10:50:53,847 [1] DEBUG TouchGFXPackages.Implementation.TouchGFXPackageStream: Filestream opened on C:\TouchGFX\4.18.0\app\packages\Simulator-2.0.0.tpa
2021-10-28 10:50:53,918 [1] DEBUG TouchGFXPackages.Implementation.TouchGFXPackageStream: Filestream opened on C:\TouchGFX\4.18.0\app\packages\Simulator-2.0.0.tpa
2021-10-28 10:50:55,074 [15] ERROR Utils.WebHandling.WebHandler: The remote server returned an error: (409) Conflict.
2021-10-28 10:50:56,948 [10] ERROR Utils.WebHandling.WebHandler: The remote server returned an error: (409) Conflict.
2021-10-28 10:50:58,956 [10] ERROR Utils.WebHandling.WebHandler: The remote server returned an error: (409) Conflict.
2021-10-28 10:50:59,216 [9] INFO TouchGFXPackages.Implementation.FileDownloader: Take operation was canceled. IsCancellationRequested=True
2021-10-28 10:50:59,233 [1] INFO TouchGFXDesigner.Main.MainWindow: Application closed
2021-11-02 04:13 AM
Sorry for jumping in. I have the same problem. I don't have to access the internet for our development so far. However, I can't open my project file because the proxy error occurs continuously. My log file is the attached. Could you please tell me how to stop accessing your server.
2021-11-03 04:36 AM
Are you able to enter your proxy logins ? From the log file it seems you never have.
/Romain
2021-11-03 05:13 AM
https://www.ssllabs.com/ssltest/analyze.html?d=packages.touchgfx.com still shows "Certificate name mismatch".
According to my local IT, this is the reason why our Proxy blocks access.
Can you please fix this issue?
Thanks.
2021-11-03 05:58 AM
Yes you wrote that 3 times :grinning_face_with_sweat: I have not replied on this as I am waiting for feedback from the Designer team. This is the first time we hear/face this so this confuses us a bit.
/Romain
2021-11-03 03:38 PM
Yes, I can. This answer is written with same PC and proxy.
I think it takes long time for resolve. I'd like to know how to edit TouchGFX project without proxy access. I don't have to access the internet for our development so far.
2021-11-03 03:39 PM
2021-11-04 07:03 AM
If I understood correctly what I was told recently this is not possible with TouchGFX 4.17 and 4.18.0 as the touchgfx.config file in the TouchGFX instalation folder was removed. It should/may be re - introduced back with TouchGFX 4.18.1, if not then TouchGFX 4.19.
For now I can only recommend to use TouchGFX 4.16.1 if you are not able to work with 4.18 even with the tpas I shared.
/Romain
