Dynamic display rotation for touchgfx.
pranavmv012
I am using a 480*480 display(st7701s driver) with STM32H745BIT6. I would like to rotate the touchgfx screen dynamically based accelerometer output. How to do this. I would like to rotate the screen 0, 90, 180 and 270 degrees and should be possible as the width is equal to height.
Thanks in advance.
LouisB
Hello @pranavmv012,
You may look at the SnapshotWidget | TouchGFX Documentation ,that allows you to copy the framebuffer and store it in a bitmap.
BR,
Louis BOUDO
ST Software Engineer | TouchGFX
