2019-10-17 10:20 AM
I want to try to make pattern password screen used in this video. Does this project have a accessible source code or document to get sample?
https://youtu.be/FzBZeZQOG_k?t=183
2019-10-22 02:47 AM
Try choosing "TouchGFX Demo 2" from the UI templates from within the touchgfx designer. You'll have access to all the source code if you create a new application based on that.
/Martin
2019-10-22 02:47 AM
/Martin
2019-10-22 02:48 AM
(I forget which screen this is implemented in but i think it has something to do with home-control).
2019-10-22 09:32 AM
Hi Martin,
Thank you for answer. I found it :)
