2019-01-11 04:44 AM
The knowledge base text in widget->Circle shows 4 widgets (Box, Box with Border, Line and Circle) on the SHAPES, and the text indicates:
"The Circle is located under Shapes in the TouchGFX Designer."
Sorry, but, where is Shapes on the TouchGFX Designer?
2019-01-11 05:02 AM
Hi @DAmig,
Additional shapes (Circle, Line, BoxWithBorder) were introduced as Widgets in the 4.10.0 release of TouchGFX (Adding to the existing shape: Box).
Best regards,
Martin
2019-01-11 05:29 AM
2019-01-11 06:32 AM
@DAmig,
Correct, what we've been doing (among other things of course) since 4.8.0 is basically to make Widgets that are already available within the framework, available from the designer.
Best regards,
Martin
2019-01-11 11:16 AM
2019-01-12 01:17 AM
@DAmig, you can have both versions installed side by side. They'll go into the c:\touchgfx\4.9.3 and \4.10.0 folders =) But if you just want to upgrade and use 4.10.0 exclusively, go ahead and uninstall 4.9.3.
You can then open your 4.9.3 application inside 4.10.0 and it will prompt you to upgrade the application and you now have access to the new widgets. Let me know how it works out!
Best regards,
Martin
2019-01-16 02:29 PM
2019-01-25 04:31 AM
Hi Daniel,
I'm not entirely sure what your problem is. And i'm not seeing your attachments? First off, glad 4.10.0 is working for you! Which tutorial are you following?
Let me know.
Best regards,
Martin
2019-01-25 10:17 AM
2019-01-31 12:22 AM
Hi @DAmig,
I still haven't received the log, hmm. Are you trying to attach it to this post?
