2024-09-25 8:06 AM - last edited on 2024-09-25 8:08 AM by Andrew Neil
(Moved from Feedback to the TouchGFX forum)
Hi there TouchGFX team!
How can I setup a round display and develop the UI for it? I haven't decided yet on the display but I just want to make TouchGFX can work with round displays
Thanks a lot in advance
2024-09-25 8:12 AM
2024-09-25 8:12 AM
2024-09-26 3:12 AM
Hello @JPabl.1 ,
In addition to Andrew's answer, I would advise you to check the STM32U5G2-DK1 and STM32U5G2-DK2 TBS that are available on TouchGFX Designer. They use the same chip but one have a round display while the other have a standard regular display, you can therefore compare them and better understand what need to be changed.
Regards,
2024-10-18 7:16 AM
Hello @JPabl.1 ,
Have you been able to move forward with your question?
Regards,
