Run target on STM32H747I-DISCO failed
victagayun
Senior III
Hello
I am using graph on STM32H747I-DISCO. Running simulation is ok, like having the sine wave on it but when I click "Run Target" I get this error...
Run Target
    Generate
        Done
    Generate Assets
        make -f simulator/gcc/Makefile assets -j8
        Converting images
        Reading ./application.config
        Done
    Post Generate
        touchgfx update_project --project-file=simulator/msvs/Application.vcxproj && touchgfx update_project --project-file=../EWARM/TouchGFX.ewp
        Done
    Compile
        make -f ../gcc/Makefile -j8
        STM32CubeProgrammer is placed in Program Files
        Converting images
        Reading TouchGFX/application.config
        Linking TouchGFX/build/bin/target.elf
        Producing additional output formats...
          target.hex   - Combined internal+external hex
          intflash.elf - Internal flash, elf debug
          intflash.hex - Internal flash, hex
          extflash.bin - External flash, binary
        Done
    Flash
        make -f ../gcc/Makefile -j8 flash
        Converting images
                               STM32CubeProgrammer v2.5.0
        ST-LINK SN  : 003100173137511539383538
        ST-LINK FW  : V3J7M2
        Board       : STM32H747I-DISCO
        Voltage     : 3.23V
        Error: ST-LINK error (DEV_TARGET_NOT_HALTED)
        2nd connect tentative with a lower frequency (8MHz)
        ST-LINK FW  : V3J7M2
        Voltage     : 3.23V
        gcc/Makefile:334: recipe for target '_extflash_' failed
        make[1]: *** [_extflash_] Error 1
        make: *** [flash] Error 2
        ../gcc/Makefile:50: recipe for target 'flash' failed
        Failed
    Failed
Yes, it is working on 2.5.0, see my previous answer (at the end)...
5 REPLIES 5
victagayun
Senior III
Any demo would display the same error...
victagayun
Senior III
I use on another PC with cubeprogrammer 2.6.0, here is different error.
Run Target
    Generate
        Done
    Generate Assets
        Converting images
        Done
    Post Generate
        Done
    Compile
        Converting images
        Done
    Flash
        Converting images
                               STM32CubeProgrammer v2.6.0
        Error: External loader C:\Program cannot be loaded.
        Error: External loader Files\STMicroelectronics\STM32Cube\STM32CubeProgrammer\bin\ExternalLoader\MT25TL01G_STM32H747I-DISCO.stldr cannot be loaded.
        ST-LINK FW  : V3J7M2
        Voltage     : 3.24V
        SWD freq    : 24000 KHz
        Connect mode: Normal
        Reset mode  : Software reset
        Device ID   : 0x450
        Revision ID : Rev V
        Device name : STM32H7xx
        Flash size  : 2 MBytes
        Device type : MCU
        Device CPU  : Cortex-M7/M4
        Memory Programming ...
        Opening and parsing file: target.hex
          File          : target.hex
          Address       : 0x08000000
        Erasing internal memory sector 0
        Erasing memory corresponding to segment 1:
        Erasing internal memory sectors [0 1]
        Erasing memory corresponding to segment 2:
        Download in Progress:
        ±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±± 0%
        ÛÛÛÛÛÛÛÛÛÛ 20%
        Error: failed to download Segment[2]
        Error: failed to download the File
        Hard reset is performed
        Failed
    Failed
previous error using another PC with cubeprogrammer 2.5.0 seems to be ok now.
Shripal_k
@victagayun​  I am also having exactly same problem when trying with STM32CubeProgrammer V2.6.0 on STM32H747i-Disco board. Can someone please provide any solution.
Run Target
    Generate
        Done
    Generate Assets
        Converting images
        Done
    Post Generate
        Done
    Compile
        Converting images
        Done
    Flash
        Converting images
        ST-LINK SN  : 002B00453137510D39383538
        ST-LINK FW  : V3J3M2
        Board       : STM32H747I-DK
        Voltage     : 3.23V
        Device ID   : 0x450
        Revision ID : Rev V
        Device type : MCU
          File          : target.hex
        ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ 100%
        Failed
    Failed
Could you download and try STM32CubeProgrammer 2.5 ? There are issues with the latest version 2.6 so we recommend to not use 2.6 until the next patch release.
/Romain
