"const Rect & Drawable::getRect ()" prohibits use as a parameter in e.g. "Screen::invalidateRect ()"
ferro
Senior III
Hi Gfx Team,
Could Drawable::getRect () in Drawable.hpp
const Rect & getRect() const
    return rect;
be changed to
Rect getRect() const
    return rect;
so it can be used as a parameter in e.g.
void Screen::invalidateRect ( Rect & invalidatedArea ) const
    container.invalidateRect ( invalidatedArea );
With the current implementation one has to write
Screen::invalidateRect ( Rect { Drawable::getRect () } );
If not, could you add a variation e.g.
Rect getRectValue() const
    return rect;
Ferro
Hello @ferro ,
Thank you for the good suggestion. I think it would be easier if you use Drawable.invalidateRect() to avoid dealing with coordination conversion (for instance, from local to global).
But, anyway, you can easily copy Drawable.hpp to your project and apply changes to it. For example, you can overload the invalidateRect() like this:
void invalidateRect (const Rect& invalidatedArea) const
     Rect r = invalidatedArea;
     invalidateRect(r);
You can read more about apply changes to widgets here
I hope this helps you,
Best regards
Mohammad MORADI
1 REPLY 1
Hello @ferro ,
     invalidateRect(r);
Best regards
Mohammad MORADI
