2023-03-08 11:45 PM
I am learning touchGFX by document. Almostly, I have no question, but in tutarial6(https://support.touchgfx.com/4.21/docs/tutorials/tutorial-06/tutorial-06-part-1), I have some issue as below, there seems some characters can NOT display normally at wildcard mode.
Thanks.
2023-03-09 01:19 AM
Hello Junde,
You need to set the wildcard characters or the wildcard range in order to make it work 🙂
In tutorial 6, you'll notice that the range "a-z,0-9,A-Z" is set to be able to display these characters in a wildcard.
/Osman
2023-03-09 12:57 AM
All of the languages need add the wildcard range as below:
2023-03-09 01:19 AM
Hello Junde,
/Osman
2023-03-09 06:56 AM
Hello @Osman SOYKURT ,
Thanks for your reply. You are right, I found I forget to add the wildcard range for others langrage.
2023-03-09 09:26 AM
This waste space in flash with chars never used. Normal way is add only dont used chars (in static text) planed in <> value place.
