2024-08-21 07:59 AM
I tried to send a LIN frame by creating a task .
The code didn't conatin any error but the frame wasn't sent
What could be the problem ?
This is my project
2024-08-21 08:32 AM
This is not TouchGFX subject and I'm wondering why you start with a complex example to debug LIN while you can start with a very simple one?
Start with a simple LIN project and debug it before going forward with TouchGFX and FreeRTOS.
2024-08-21 08:40 AM
I tried a simple LIN project "sending a LIN frame" using an ST board and it worked fine but when i used touchGFX the frame wasn't sent
2024-08-21 09:00 AM
This statement is important to locate the issue and normally it should said from the beginning 😉
So you have an issue in your GUI programming. I let my TouchGFX colleagues help you.
