2024-05-15 09:52 AM
Dear Gfx Team,
Please be so kind and fix the code generating Visual Studio project so the capitalization of the screen names is the same as seen in GfxDesigner. It is very difficult to read in all lower case.
Why all lower case ? Does not help with readibility.
Thank you
Ferro
2024-06-21 02:25 AM
Hello @ferro ,
After discussing with the team, we have decided to maintain the folder names in lowercase to avoid potential complications that could arise from making changes (like for people working on case-sensitive systems).
2024-05-16 03:26 AM
Hello @ferro ,
Thank you so much for your valuable comment. You are absolutely right; using all lowercase letters impairs readability, but unfortunately, we don't have a solution for it at the moment.
I will share this issue with the rest of the team.
Best regards,
2024-05-16 03:42 AM
Thank you for prompt reply @Mohammad MORADI ESFAHANIASL .
"I will share this issue with the rest of the team."
Please do. Thanks.
2024-05-16 04:16 AM
For sure, we need our lovely community's feedback and opinions to make TouchGFX better and better, so thank you for helping us :folded_hands:
2024-06-21 02:25 AM
Hello @ferro ,
