Post storing graphical data to external QSPI flash, Text is flickering for fade settings at Touchgfx
Hello, After load data from external flash memory display intial text is flickering. Please check video using below link.
https://drive.google.com/file/d/1Y_qbsM-2iQcHDFH6mA2lt7MuAzxujCqu/view?usp=sharing
I have added below fade settings in touchgfx.
I m displaying logo and text "REVOS" for 1 second before main screen and during same time display is flickering. When I was storing data in internal flash, there was no such issue.
4 REPLIES 4
Alexandre RENOUX
Principal
What board are you using ?
Maybe your QSPI Flash is not initialized correctly. Is it only the text flickering or other assets such as bitmaps as well ?
/Alexandre
Only text was flickering but it got solved with change in clock speed for QSPI.
Previously i was using QSPI prescaler as 2 (means 200/3 = 66.7 mhz) but when i changed to 1 ( means clock speed 200/2 = 100 mhz) issue got solved.
Perfect. Good to know you solved your issue :thumbs_up:
/Alexandre
