Menu lcd
‎2011-03-13 5:48 AM
Hello all
I'm about to display a menu on a touch screen in a map STM3210C board eval based on ?C stm32f107VCT.
Will you help me to send a library (menu.c. h) makes a little work.
Thank you very much.
Best regards
#lcd- Labels:
LCD-LTDC
‎2011-03-13 6:45 AM
Example of the files you are looking for is available from the demo firmware package of the corresponding evaluation board (http://www.st.com/internet/com/SOFTWARE_RESOURCES/SW_COMPONENT/FIRMWARE/stm3210c-eval_fw.zip
). Best Regards, Thierry PS: Please note that such request should be entered into the STM32 section. The STMTouch section is related to touch sensing solutions.- Mark as New
‎2011-03-13 10:07 AM
Thank you
for your
reply
I have
this
file
my problem
now
is
how
to determine
cursor
knob to
XY
, I
work
with
3.2
TFT
LCD
240x320
pixel
resolution
, here is
a
piece of code
static
ts_stat
ts_stat
Update the
structure
With The
current
position
Ts_stat
IOE_TS_GetState
if (
ts_stat
TouchDetected
ts_stat
Y
220
ts_stat
Y
180)
if (
ts_stat
X
> 10
ts_stat
X
70)
External
Interrupt
Disable
IntExtOnOffConfig
DISABLE
LCD_SetDisplayWindow
210
290
65
, 262
LCD_WriteBMP
u32
telnet_image
GL_PageControls_TypeDef
TestBtn1
NewButton
TestBtn1
Diagnostic
Menu
FuncMenu
External
Interrupt
Enable
IntExtOnOffConfig
ENABLE
IOE_ITConfig
IOE_ITSRC_TSC
FuncMenu
Best regards
‎2011-04-10 2:51 AM
Please use the Cortex-Mx STM32 forum to request general support on STM32 devices and on associated tools/firmware. This forum is related to STMTouch touch sensing solutions.
Best Regards,
Thierry,
