Linker error with provided ARMCLANG library from TouchGfx 4.14.0
2020-07-29 10:39 PM
Hi @Martin KJELDSEN
I just updated to 4.14.0. Now I get the linker as I got them in this thread (the problem was the short enums/wchar settings) https://community.st.com/s/question/0D50X0000AlgbG2SQI/arm6-compiler-support
I can see that the armclang lib that comes with 4.14.0 is smaller than the version you provided in the thread.
Any thoughts?
Cheers /jimmii
TouchGFX
2020-08-10 5:04 AM
2020-08-10 6:45 AM
Hey @Martin KJELDSEN
Looks good. (At least for my project).
Thanks a lot.
/jimmii
2021-01-11 6:57 AM
Hi @Martin KJELDSEN
Would you be so kind to provide me with the new library for 4.16.0 as you did for the last versions?
Thanks a lot.
2021-01-12 1:09 AM
Hi Jimmii,
Yes i would be so kind - I'll put it on my list.
/Martin
2021-01-25 9:36 PM
Hi @Martin KJELDSEN , how does it look? Did you have any chance to compile the library for me?
Thanks.
2021-01-26 5:08 AM
I'll do it now - Just brushing up on your compiler settings
2021-01-26 5:23 AM
2021-01-26 5:24 AM
Let me know how it works for you @Roman Schläpfer
-xc -std=c99 --target=arm-arm-none-eabi -mcpu=cortex-m7 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -c -fno-rtti -funsigned-char -fshort-enums -fshort-wchar -mlittle-endian -gdwarf-3 -Oz -ffunction-sections
/Martin
2021-01-27 1:03 AM
Thanks @Martin KJELDSEN , I ill have a look as soon as I'm back from vacation.
2021-01-27 1:20 AM
Ok @Roman Schläpfer - Are you saying working on TouchGFX projects is not like vacation? Have a great time off :D
