Linker error with provided ARMCLANG library from TouchGfx 4.14.0
jimmii
Senior II
Hi @Martin KJELDSEN​
I just updated to 4.14.0. Now I get the linker as I got them in this thread (the problem was the short enums/wchar settings) https://community.st.com/s/question/0D50X0000AlgbG2SQI/arm6-compiler-support
I can see that the armclang lib that comes with 4.14.0 is smaller than the version you provided in the thread.
Any thoughts?
Cheers /jimmii
43 REPLIES 43
Hey @Martin KJELDSEN​
Looks good. (At least for my project).
Thanks a lot.
/jimmii
Would you be so kind to provide me with the new library for 4.16.0 as you did for the last versions?
Thanks a lot.
Hi Jimmii,
Yes i would be so kind - I'll put it on my list.
/Martin
Hi @Martin KJELDSEN​ , how does it look? Did you have any chance to compile the library for me?
Thanks.
​I'll do it now - Just brushing up on your compiler settings
Let me know how it works for you @Roman Schläpfer​
-xc -std=c99 --target=arm-arm-none-eabi -mcpu=cortex-m7 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -c -fno-rtti -funsigned-char -fshort-enums -fshort-wchar -mlittle-endian -gdwarf-3 -Oz -ffunction-sections
/Martin
Thanks @Martin KJELDSEN​ , I ill have a look as soon as I'm back from vacation.
​Ok @Roman Schläpfer​ - Are you saying working on TouchGFX projects is not like vacation? Have a great time off :D
