Issue with importing translations into TouchGFX!!!
manto.1
I sucessfuly exported texts.xml with translations.rb
but when I try to import .xlsx back to .xml. I get the error sheet Typography not found!?
> translations.rb import texts.xlsx texts.xml
sheet 'Typography' not found
An error occurred during translations import!
Bellow are the files used
ferro
Lead
Could not be the problem in swapped .xml and .xlsx extentions in your command ?
Here is what my system shows:
0693W00000YA557QAD.pngAlso, my conversions run without .xsd file present.
8 REPLIES 8
Romain DIELEMAN
Could you share which TouchGFX version you are working with ? Are you sure you are working in the correct folder/path ? (since the error message says that it cannot find Typography tool)
/Romain
manto.1
I am working with TouchGFX 4.20.0
manto.1
I copied the texts.xml and texts.xlsx to the folder where TouchGFX is installed where the translations.rb file is:
(..\TouchGFX\4.20.0\touchgfx\framework\tools\textconvert)
Then I run the command:
ruby translations.rb import texts.xlsx texts.xml
manto.1
Did you found any solution. I think I am in the corect path/folder because export works fine. Also the error sais it cannot find typography sheet not tool, or is this the same?
manto.1
Found the solution.
It is necesary to copy also the texts.xsd file to the path. This was not clearly specified in the documentation.
https://support.touchgfx.com/4.20/docs/development/ui-development/touchgfx-engine-features/texts-and-fonts
ferro
Lead
