Image defect
‎2020-02-15 8:44 AM
‎2020-02-16 3:25 AM
Hm.... I can delete vertical lines near pictures if I use 32-bit SDRAM as 16-bit (I reconfigured FMC). But I want to use all 32 bit. Is it bug of your library?
And stripes on circle still present, even in 16 bit mode....
‎2020-02-16 5:23 AM
Stripes on circle disappeared, if I use RGB565...
But I want RGB888.
How?
‎2020-02-16 11:32 PM
Just to be sure, could we see your code? It might be due to some missing invalidated widgets. If not, some more details on your project would be useful to have a better insight of this issue. Thanks,
/Romain
‎2020-02-16 11:51 PM
Thanks!​
I will upload code in the evening, since 7 hour after this post.
Look at this topic later, please.​
‎2020-02-17 1:01 AM
Please provide more details on which MCU you're working with, how you created the project, etc.
/Martin
‎2020-02-17 1:25 AM
Stm32f746be, ​MT48LC4M32B2P-6A
Project created with cumbeMX 5.5 and last version of touchgfxdesigner.
I'll upload project here later.​
‎2020-02-17 2:41 AM
Look at the project
‎2020-02-17 2:42 AM
Look at the project
‎2020-02-17 7:48 AM
YESS!
Half of problem solved!!!!!
CubeMX hasn't automatically generated MPU_Config for SDRAM! It generated it only for qSPI (address 0x90000000)
I added this code
void MPU_Config(void)
MPU_Region_InitTypeDef MPU_InitStruct = {0};
/* Disables the MPU */
HAL_MPU_Disable();
/** Initializes and configures the Region and the memory to be protected
MPU_InitStruct.Enable = MPU_REGION_ENABLE;
MPU_InitStruct.Number = MPU_REGION_NUMBER0;
MPU_InitStruct.BaseAddress = 0xD0000000;
MPU_InitStruct.Size = MPU_REGION_SIZE_16MB;
MPU_InitStruct.SubRegionDisable = 0x0;
MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL1;
MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS;
MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_ENABLE;
MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE;
MPU_InitStruct.IsCacheable = MPU_ACCESS_CACHEABLE;
MPU_InitStruct.IsBufferable = MPU_ACCESS_BUFFERABLE;
HAL_MPU_ConfigRegion(&MPU_InitStruct);
MPU_InitStruct.Number = MPU_REGION_NUMBER1;
MPU_InitStruct.Size = MPU_REGION_SIZE_2MB;
MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_DISABLE;
MPU_InitStruct.Number = MPU_REGION_NUMBER2;
MPU_InitStruct.BaseAddress = 0xD0200000;
MPU_InitStruct.Number = MPU_REGION_NUMBER3;
MPU_InitStruct.BaseAddress = 0x90000000;
MPU_InitStruct.Size = MPU_REGION_SIZE_256MB;
MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0;
MPU_InitStruct.AccessPermission = MPU_REGION_NO_ACCESS;
MPU_InitStruct.IsCacheable = MPU_ACCESS_NOT_CACHEABLE;
MPU_InitStruct.IsBufferable = MPU_ACCESS_NOT_BUFFERABLE;
MPU_InitStruct.Number = MPU_REGION_NUMBER4;
MPU_InitStruct.AccessPermission = MPU_REGION_PRIV_RO;
/* Enables the MPU */
HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
And stripes on circle disappears! And other widgets looks very well.
But stripes near widgets still present.
Look to the code, that i posted (MPU_Config) May be something still wrong?
