TouchGFX Designer 4.25 won't load image preview of projects
nico23
Senior III
I've updated from TouchGFX Designer 4.24 to 4.25 and I've noticed that the example projects won't load the previews. Same machine, same internet connection
4.25
4.24
nico23
Senior III
I've opened and close various time and it showed it again
5 REPLIES 5
GaetanGodart
Hello @nico23 ,
Can you check your proxy settings :
And make sure you do not have a pink triangle on the top left of your screen.
Gaetan Godart
Software engineer at ST (TouchGFX)
nico23
Senior III
So closing and re-opening TouchGFX Designer solved the issue?
Gaetan Godart
yup, did that 2/3 times and preview re-appeared (internet was working properly, no proxy was set and no triangle appeared)
Ok, glad to hear that!
Gaetan Godart
