I'm looking for a remote camera solution from STM32L4 mcu dcmi interface through ~20meters long STP cable using serdes IC like the STSMIA832. I don't care using all 4 pairs of the stp-utp cable. Will this work ? Regards
tbelo
5 REPLIES 5
tbelo
Ok, but the project requires no wifi and wired connection to the mcu
For commercial project you'd probably want to discuss with an FAE
App Note suggests there are evaluations boards, and the connectivity seems equivalent to DCMI
https://www.st.com/content/ccc/resource/technical/document/application_note/8f/8b/39/25/03/ea/42/b8/CD00226703.pdf/files/CD00226703.pdf/jcr:content/translations/en.CD00226703.pdf
tbelo
I have my doubts about the STSMIA832.
First because mouser report it as obsolete and second the application note uses a camera with an interface called "SMIA".
Not sure about this IC !
Anyone for ST can advice ?
App Note is 8 years old, should tell you what you need to know about the efficacy.
ST doesn't really operate sales/support here, call your local office, or find regional sales individuals via LinkedIn
In 2018 people doing cameras over twisted pairs are using Ethernet w/PoE
