2019-08-28 07:07 PM
Hi:
I have an spi TFT screen,and how to port the TouchGFX on this Sreen?
Thanks!!
2019-09-23 07:48 PM
Hi Martin:
Thanks your help! It can display on TFT by touchgfx.
Best regards!
Jack li
2019-09-23 11:49 PM
That's great, @Jack li!
/Martin
2019-09-24 04:32 AM
I forgot to mention that if you are- or intend on using DMA to transfer to your display then you should syncronize on the DMA completed event before you return from flushFrameBuffer()
/Martin
2020-04-09 12:00 PM
Hello, would you share your solution?
Best regards!
