How can I get trigers button click and button unclick?
Ayagb.2239
I want to use a button, than I need button click and unclick time execute virtual function. How can it?
Thanks.
HPham.1590
I'm not really understand what's you want, but as my guest, I think you need to call function when the button Pressed and one again when Released.
You can refer this function, add to ScreenView.cpp. and dont forget to define it at header file.
Best Regard,
Hieu
void Screen1View::handleClickEvent(const ClickEvent& evt)
	if (your_object.getRect().intersect(Rect(evt.getX(), evt.getY(), 1, 1)))
			if (evt.getType() == ClickEvent::PRESSED)
				// Your code when Pressed
			if (evt.getType() == ClickEvent::RELEASED)
				// Your code when Released
7 REPLIES 7
Alexandre RENOUX
Principal
Can you reformulate your question and maybe elaborate ? I unfortunately don't understand your issue.
/Alexandre
HPham.1590
Best Regard,
Hieu
Ayagb.2239
Thank you, HPham and Alexandre,
My question: I need to get signal when pressed a button and released button. This answer is ok for me.....
B.Regards.
Ahmet.
Ayagb.2239
Thank you…. Code Worked fine….
you should set this question is answered, it'll help others person
Hieu
PCu1
Ayagb.2239
Thank you Pierre,
I will try it.
Ahmet.
