GFX designer invalid patch STM32F7 disco
Vojtěch
I created a project in Touch GFX designer. Then I open in STM32cubeIDE, but I get a warning:
Description   Resource   Path   Location   Type
Invalid project path: Include path not found (C:\TouchGFXProjects\MyApplication_1\Middlewares\Third_Party\FreeRTOS\Source\CMSIS_RTOS).   STM32F746G_DISCO      pathentry   Path Entry Problem
thank you for answer
6 REPLIES 6
Yoann KLEIN
Hello @Vojt?ch​ ,
Did you enable FreeRTOS in CubeMX and generated code ?
/Yoann
Yoann KLEIN
Vojtěch
My project was generated by Touch gfx designer. Then I ran the code in stm32cubeIDE.
Yoann KLEIN
I cannot reproduce your error, which version of TouchGFX are you using ?
Yoann KLEIN
Vojtěch
Touch GFX 4.20.0
Yoann KLEIN
Could you please generate code in CubeMX for this project ?
Yoann KLEIN
Karl Yamashita
Lead II
Somehow your path to /Third_Party/FreeRTOS/Source/CMSIS_RTOS doesn't seem right if you had TouchGFX generate the code.
When I create a project from TouchGFX, import into STM32CubeIDE and build, I see /Third_Party/FreeRTOS/Source/CMSIS_RTOS_V2
I Can't Believe It's Not Butter. If you find my answers useful, click the accept button so that way others can see the solution.
