DSI display interface doesn't work
PZamb.2
Hi
I'm development a board with STM32F779a cpu connect with dsi display.
I create the graphic wit TouchFX tools and included in the STM32cube ide design software.
How example I see STM32f769i-disco demo, and received the init code of display by producer.
My problem is that the DSI Host not run, no signal appare , I'm monitoring with oscilloscopie.
What may be the problem ?
int main(void)
 /* USER CODE BEGIN 1 */
 /* USER CODE END 1 */
 HAL_Init();
 /* USER CODE BEGIN Init */
 /* USER CODE END Init */
 SystemClock_Config();
 /* USER CODE BEGIN SysInit */
 /* USER CODE END SysInit */
 MX_GPIO_Init();
 MX_LTDC_Init();
 MX_CRC_Init();
 MX_DSIHOST_DSI_Init();
 MX_FMC_Init();
 MX_QUADSPI_Init();
 MX_DMA2D_Init();
 MX_TouchGFX_Init();
 /* Call PreOsInit function */
 MX_TouchGFX_PreOSInit();
 /* USER CODE BEGIN 2 */
 /* USER CODE END 2 */
 /* Init scheduler */
 osKernelInitialize();
 /* USER CODE BEGIN RTOS_MUTEX */
 /* add mutexes, ... */
 /* USER CODE END RTOS_MUTEX */
 /* USER CODE BEGIN RTOS_SEMAPHORES */
 /* add semaphores, ... */
 /* USER CODE END RTOS_SEMAPHORES */
 /* USER CODE BEGIN RTOS_TIMERS */
 /* start timers, add new ones, ... */
 /* USER CODE END RTOS_TIMERS */
 /* USER CODE BEGIN RTOS_QUEUES */
 /* add queues, ... */
 /* USER CODE END RTOS_QUEUES */
 /* Create the thread(s) */
 /* creation of defaultTask */
 defaultTaskHandle = osThreadNew(StartDefaultTask, NULL, &defaultTask_attributes);
 /* USER CODE BEGIN RTOS_THREADS */
 /* add threads, ... */
 /* USER CODE END RTOS_THREADS */
 /* USER CODE BEGIN RTOS_EVENTS */
 /* add events, ... */
 /* USER CODE END RTOS_EVENTS */
 /* Start scheduler */
 osKernelStart();
 /* We should never get here as control is now taken by the scheduler */
 /* Infinite loop */
 /* USER CODE BEGIN WHILE */
 while (1)
   /* USER CODE END WHILE */
   /* USER CODE BEGIN 3 */
13 REPLIES 13
PZamb.2
static void MX_DSIHOST_DSI_Init(void)
 /* USER CODE BEGIN DSIHOST_Init 0 */
   // Reset DSI Display
   HAL_GPIO_WritePin(DSI_reset_GPIO_Port, DSI_reset_Pin, GPIO_PIN_RESET);
   HAL_Delay(20);
   HAL_GPIO_WritePin(DSI_reset_GPIO_Port, DSI_reset_Pin, GPIO_PIN_SET);
   HAL_Delay(20);
 /* USER CODE END DSIHOST_Init 0 */
 DSI_PLLInitTypeDef PLLInit = {0};
 DSI_HOST_TimeoutTypeDef HostTimeouts = {0};
 DSI_PHY_TimerTypeDef PhyTimings = {0};
 DSI_LPCmdTypeDef LPCmd = {0};
 DSI_CmdCfgTypeDef CmdCfg = {0};
 /* USER CODE BEGIN DSIHOST_Init 1 */
 /* USER CODE END DSIHOST_Init 1 */
 hdsi.Instance = DSI;
 hdsi.Init.AutomaticClockLaneControl = DSI_AUTO_CLK_LANE_CTRL_DISABLE;
 hdsi.Init.TXEscapeCkdiv = 3;
 hdsi.Init.NumberOfLanes = DSI_TWO_DATA_LANES;
 PLLInit.PLLNDIV = 103;
 PLLInit.PLLIDF = DSI_PLL_IN_DIV7;
 PLLInit.PLLODF = DSI_PLL_OUT_DIV1;
 if (HAL_DSI_Init(&hdsi, &PLLInit) != HAL_OK)
   Error_Handler();
 HostTimeouts.TimeoutCkdiv = 1;
 HostTimeouts.HighSpeedTransmissionTimeout = 0;
 HostTimeouts.LowPowerReceptionTimeout = 0;
 HostTimeouts.HighSpeedReadTimeout = 0;
 HostTimeouts.LowPowerReadTimeout = 0;
 HostTimeouts.HighSpeedWriteTimeout = 0;
 HostTimeouts.HighSpeedWritePrespMode = DSI_HS_PM_DISABLE;
 HostTimeouts.LowPowerWriteTimeout = 0;
 HostTimeouts.BTATimeout = 0;
 if (HAL_DSI_ConfigHostTimeouts(&hdsi, &HostTimeouts) != HAL_OK)
   Error_Handler();
 PhyTimings.ClockLaneHS2LPTime = 24;
 PhyTimings.ClockLaneLP2HSTime = 25;
 PhyTimings.DataLaneHS2LPTime = 13;
 PhyTimings.DataLaneLP2HSTime = 18;
 PhyTimings.DataLaneMaxReadTime = 0;
 PhyTimings.StopWaitTime = 0;
 if (HAL_DSI_ConfigPhyTimer(&hdsi, &PhyTimings) != HAL_OK)
   Error_Handler();
 if (HAL_DSI_ConfigFlowControl(&hdsi, DSI_FLOW_CONTROL_BTA) != HAL_OK)
   Error_Handler();
 if (HAL_DSI_SetLowPowerRXFilter(&hdsi, 10000) != HAL_OK)
   Error_Handler();
 if (HAL_DSI_ConfigErrorMonitor(&hdsi, HAL_DSI_ERROR_NONE) != HAL_OK)
   Error_Handler();
 LPCmd.LPGenShortWriteNoP = DSI_LP_GSW0P_ENABLE;
 LPCmd.LPGenShortWriteOneP = DSI_LP_GSW1P_ENABLE;
 LPCmd.LPGenShortWriteTwoP = DSI_LP_GSW2P_ENABLE;
 LPCmd.LPGenShortReadNoP = DSI_LP_GSR0P_ENABLE;
 LPCmd.LPGenShortReadOneP = DSI_LP_GSR1P_ENABLE;
 LPCmd.LPGenShortReadTwoP = DSI_LP_GSR2P_ENABLE;
 LPCmd.LPGenLongWrite = DSI_LP_GLW_ENABLE;
 LPCmd.LPDcsShortWriteNoP = DSI_LP_DSW0P_ENABLE;
 LPCmd.LPDcsShortWriteOneP = DSI_LP_DSW1P_ENABLE;
 LPCmd.LPDcsShortReadNoP = DSI_LP_DSR0P_ENABLE;
 LPCmd.LPDcsLongWrite = DSI_LP_DLW_ENABLE;
 LPCmd.LPMaxReadPacket = DSI_LP_MRDP_ENABLE;
 LPCmd.AcknowledgeRequest = DSI_ACKNOWLEDGE_ENABLE;
 if (HAL_DSI_ConfigCommand(&hdsi, &LPCmd) != HAL_OK)
   Error_Handler();
 CmdCfg.VirtualChannelID = 0;
 CmdCfg.ColorCoding = DSI_RGB565;
 CmdCfg.CommandSize = 200;
 CmdCfg.TearingEffectSource = DSI_TE_EXTERNAL;
 CmdCfg.TearingEffectPolarity = DSI_TE_RISING_EDGE;
 CmdCfg.HSPolarity = DSI_HSYNC_ACTIVE_LOW;
 CmdCfg.VSPolarity = DSI_VSYNC_ACTIVE_LOW;
 CmdCfg.DEPolarity = DSI_DATA_ENABLE_ACTIVE_HIGH;
 CmdCfg.VSyncPol = DSI_VSYNC_FALLING;
 CmdCfg.AutomaticRefresh = DSI_AR_DISABLE;
 CmdCfg.TEAcknowledgeRequest = DSI_TE_ACKNOWLEDGE_ENABLE;
 if (HAL_DSI_ConfigAdaptedCommandMode(&hdsi, &CmdCfg) != HAL_OK)
   Error_Handler();
 if (HAL_DSI_SetGenericVCID(&hdsi, 0) != HAL_OK)
   Error_Handler();
 /* USER CODE BEGIN DSIHOST_Init 2 */
 /* USER CODE END DSIHOST_Init 2 */
 * @brief LTDC Initialization Function
 * @param None
 * @retval None
static void MX_LTDC_Init(void)
 /* USER CODE BEGIN LTDC_Init 0 */
 /* USER CODE END LTDC_Init 0 */
 LTDC_LayerCfgTypeDef pLayerCfg = {0};
 /* USER CODE BEGIN LTDC_Init 1 */
 /* USER CODE END LTDC_Init 1 */
 hltdc.Instance = LTDC;
 hltdc.Init.HSPolarity = LTDC_HSPOLARITY_AL;
 hltdc.Init.VSPolarity = LTDC_VSPOLARITY_AL;
 hltdc.Init.DEPolarity = LTDC_DEPOLARITY_AL;
 hltdc.Init.PCPolarity = LTDC_PCPOLARITY_IPC;
 hltdc.Init.HorizontalSync = 23;
 hltdc.Init.VerticalSync = 3;
 hltdc.Init.AccumulatedHBP = 73;
 hltdc.Init.AccumulatedVBP = 23;
 hltdc.Init.AccumulatedActiveW = 873;
 hltdc.Init.AccumulatedActiveH = 823;
 hltdc.Init.TotalWidth = 923;
 hltdc.Init.TotalHeigh = 831;
 hltdc.Init.Backcolor.Blue = 0;
 hltdc.Init.Backcolor.Green = 0;
 hltdc.Init.Backcolor.Red = 0;
 if (HAL_LTDC_Init(&hltdc) != HAL_OK)
   Error_Handler();
 pLayerCfg.WindowX0 = 0;
 pLayerCfg.WindowX1 = 800;
 pLayerCfg.WindowY0 = 0;
 pLayerCfg.WindowY1 = 800;
 pLayerCfg.PixelFormat = LTDC_PIXEL_FORMAT_RGB565;
 pLayerCfg.Alpha = 255;
 pLayerCfg.Alpha0 = 0;
 pLayerCfg.BlendingFactor1 = LTDC_BLENDING_FACTOR1_CA;
 pLayerCfg.BlendingFactor2 = LTDC_BLENDING_FACTOR2_CA;
 pLayerCfg.FBStartAdress = 0xC0000000;
 pLayerCfg.ImageWidth = 800;
 pLayerCfg.ImageHeight = 800;
 pLayerCfg.Backcolor.Blue = 0;
 pLayerCfg.Backcolor.Green = 0;
 pLayerCfg.Backcolor.Red = 0;
 if (HAL_LTDC_ConfigLayer(&hltdc, &pLayerCfg, 0) != HAL_OK)
   Error_Handler();
 /* USER CODE BEGIN LTDC_Init 2 */
 __HAL_LTDC_DISABLE(&hltdc);
   DSI_LPCmdTypeDef LPCmd;
   HAL_DSI_Start(&hdsi);
   MLT034S32_setup();
   //HAL_DSI_ShortWrite(&hdsi, 0, DSI_DCS_SHORT_PKT_WRITE_P1, OTM8009A_CMD_DISPOFF, 0x00);
   //DSI_IO_WriteCmd();
   LPCmd.LPGenShortWriteNoP = DSI_LP_GSW0P_DISABLE;
   LPCmd.LPGenShortWriteOneP = DSI_LP_GSW1P_DISABLE;
   LPCmd.LPGenShortWriteTwoP = DSI_LP_GSW2P_DISABLE;
   LPCmd.LPGenShortReadNoP = DSI_LP_GSR0P_DISABLE;
   LPCmd.LPGenShortReadOneP = DSI_LP_GSR1P_DISABLE;
   LPCmd.LPGenShortReadTwoP = DSI_LP_GSR2P_DISABLE;
   LPCmd.LPGenLongWrite = DSI_LP_GLW_DISABLE;
   LPCmd.LPDcsShortWriteNoP = DSI_LP_DSW0P_DISABLE;
   LPCmd.LPDcsShortWriteOneP = DSI_LP_DSW1P_DISABLE;
   LPCmd.LPDcsShortReadNoP = DSI_LP_DSR0P_DISABLE;
   LPCmd.LPDcsLongWrite = DSI_LP_DLW_DISABLE;
   HAL_DSI_ConfigCommand(&hdsi, &LPCmd);
   HAL_LTDC_SetPitch(&hltdc, 800, 0);
   __HAL_LTDC_ENABLE(&hltdc);
 /* USER CODE END LTDC_Init 2 */
MM..1
Chief III
Primary all this lines is in bad order in LTDC you start unconfigured DSI
 MX_GPIO_Init();
 MX_LTDC_Init();
 MX_CRC_Init();
 MX_FMC_Init();
 MX_QUADSPI_Init();
 MX_DMA2D_Init();
PZamb.2
Hi yes is true but is the automatic compiler, all run i must move DSIhost under LTDC
I modify the interface protocole to DSI 24Bit (Display datasheet is poor of information) and now the signal run.
PZamb.2
I don't understand because the TouchGFx application doesn't work.
I try with another application board based of same cpu but different display , i think of configured all device , memory Sdram work and external flash is loaded, configuration string from display productor.
The Touchgfx not start, i place the breakpoint to screenviewbase.cpp but the routines doesen't call.
PZamb.2
I chage the position but not work
May be some parameter is wrong
PZamb.2
PZamb.2
PZamb.2
PZamb.2
This is my .project file:
<?xml version="1.0" encoding="UTF-8"?>
<projectDescription>
   <name>Pomelli_test_funzioni</name>
   <comment></comment>
   <projects>
   </projects>
   <buildSpec>
      <buildCommand>
         <name>org.eclipse.cdt.managedbuilder.core.genmakebuilder</name>
         <triggers>clean,full,incremental,</triggers>
         <arguments>
         </arguments>
      </buildCommand>
      <buildCommand>
         <name>org.eclipse.cdt.managedbuilder.core.ScannerConfigBuilder</name>
         <triggers>full,incremental,</triggers>
         <arguments>
         </arguments>
      </buildCommand>
   </buildSpec>
   <natures>
      <nature>com.st.stm32cube.ide.mcu.MCUProjectNature</nature>
      <nature>com.st.stm32cube.ide.mcu.MCUCubeProjectNature</nature>
      <nature>org.eclipse.cdt.core.cnature</nature>
      <nature>com.st.stm32cube.ide.mcu.MCUCubeIdeServicesRevAev2ProjectNature</nature>
      <nature>com.st.stm32cube.ide.mcu.MCUAdvancedStructureProjectNature</nature>
      <nature>com.st.stm32cube.ide.mcu.MCUSingleCpuProjectNature</nature>
      <nature>com.st.stm32cube.ide.mcu.MCURootProjectNature</nature>
      <nature>org.eclipse.cdt.managedbuilder.core.managedBuildNature</nature>
      <nature>org.eclipse.cdt.managedbuilder.core.ScannerConfigNature</nature>
      <nature>org.eclipse.cdt.core.ccnature</nature>
   </natures>
</projectDescription>
