2021-08-28 9:54 PM
I've come across what seems to be a Designer bug which I don't know how to solve or how to avoid it in the future.
I added an animated image to my project that consists of a few images. Afterwards I deleted the animated image and proceeded to remove the images the Designer's images screen.
Then, to my surprise, when I tried to compile through the CubeIDE I received the following error message:
make: *** No rule to make target 'C:/TouchGFXProjects/FirstApplication/TouchGFX/generated/images/src/image_FullPallete.cpp', needed by 'Application/User/generated/image_FullPallete.o'. Stop.make: *** No rule to make target 'C:/TouchGFXProjects/FirstApplication/TouchGFX/generated/images/src/image_FullPallete.cpp', needed by 'Application/User/generated/image_FullPallete.o'. Stop.
If I re-add the images, it works fine. If I try to delete them again, the same thing happens.
I don't want these images and I don't know how to get rid of them.
Thanks in advance!
2021-08-30 12:12 AM
As Alexandre said this issue was expected to be fixed. The workaround otherwise would be to manually delete the "Debug" folder in the Tree View of your project in STM32CubeIDE.
/Romain
2021-08-29 5:28 PM
Hello CHech.1,
What version of TouchGFX are you using ?
This bug should not appear with the latest version (4.17).
/Alexandre
2021-08-30 12:12 AM
/Romain
2021-09-01 3:28 AM
Hi, i'm using 4.17
2021-09-01 3:28 AM
Thank you!
