2021-09-28 10:56 PM
I used the following menu in CubeMX to alter the Memory management scheme to heap_3, generated my code, and then switched back to heap_4:
Afterwards, when trying to run it with the CubeIDE I get the following error:
I'll note that when flashing through the TouchGFX Designer I get no such error.
I tried to switch back and forth between them, re-regenerating my code, and deleting the STM32CubeIDE/Debug folder.
Any help will be appreciated!
Thank you
2021-09-29 2:21 AM
Hello @CHech.1 ,
Thanks for your post,
Are you using the latest CubeMX version ? Otherwise, could you please share your ioc file to check it?
Thanks, Khouloud
2021-09-29 2:34 AM
2021-09-29 8:41 AM
Could you please attach the whole project?
Thanks, Khouloud
2021-10-02 10:20 PM
2021-10-05 12:00 AM
anyone...?
I temporarily solved it by manually adding an empty heap_3.c file, but this is obviously not optimal
2021-10-08 6:25 AM
Hello @CHech.1 ,
Sorry for the delay,
It will be internally checked, I'll keep you posted for any new update.
Thanks, Khouloud
