After changing freeRtos heap type - "No rule to make target..."
CHech.1
I used the following menu in CubeMX to alter the Memory management scheme to heap_3, generated my code, and then switched back to heap_4:0693W00000FAl45QAD.png
Afterwards, when trying to run it with the CubeIDE I get the following error:0693W00000FAl3dQAD.png
I'll note that when flashing through the TouchGFX Designer I get no such error.
I tried to switch back and forth between them, re-regenerating my code, and deleting the STM32CubeIDE/Debug folder.
Any help will be appreciated!
Thank you
6 REPLIES 6
Khouloud ZEMMELI
Hello @CHech.1​ ,
Thanks for your post,
Are you using the latest CubeMX version ? Otherwise, could you please share your ioc file to check it?
Thanks, Khouloud
Thank you for the quick reply!
I'm indeed using the latest version (6.3.0)
I uploaded the ioc file.
Thank you
Could you please attach the whole project?
Thanks, Khouloud
Hi, I'm sorry for the delay.
I attached the project's folder.
Thank you
CHech.1
anyone...?
I temporarily solved it by manually adding an empty heap_3.c file, but this is obviously not optimal
Hello @CHech.1​ ,
Sorry for the delay,
It will be internally checked, I'll keep you posted for any new update.
Thanks, Khouloud
