How to implement HTTPS webserver without FreeRTOS
  • March 27, 2025
  • 4 replies
  • 746 views
I built a simple HTTP webservice with an F4,
Following the code provided by this tutorial made by ControllersTech
STM32 ETHERNET #6. HTTP SERVER PART 1 || Simple Webpage - YouTube
It works well.
Now I want to secure it without adding FreeRTOS
Would be possible to implement MbedTLS without FreeRTOS?
Is there different ways to secure my webserver?
Not using FreeRTOS is a requirement for my project.
Thanks for your help
Best regard
mbarg.1
Senior III
March 27, 2025
Should you decide to move to ThreadX NetXDuo, we can help.
Hi, Have you implemented the HTTPS without RTOS.  I am also trying to add the secure for the web page. I am facing issues.
Are you implemented that code?
If you implemented that code means you need to send the document . what you changed.
LCE
Principal II
April 28, 2025
This can be used as a starting point:
http://131.159.60.228/docs/md___1_8getting_started.html
Thanks for your response.
can you provide the https implementation using nucleo-h755zi-q . Otherwise provide with dual core micro controller implementation.
