2021-12-28 6:39 PM
How to solve the problem of slow scrolllist sliding process, when the item template is too complicated(Template size :710*35,contains 4 textAreas�?2 bitmaps 5 boxs,Scrolllist size :710*350).The simulator is very nice,but H7 board is not smooth.
2022-01-04 12:10 AM
Thank you very much.I found the problem.ADC acquisition task consumes CPU resources extremely, resulting in degradation of UI performance.
2022-01-02 6:34 PM
Hello Zwei.9.
Can you share your UI ? Otherwise, it's difficult to give you any feedback.
/Alexandre
2022-01-04 12:10 AM
2022-01-04 3:22 AM
Hello Zwei.9,
Glad to hear that you fixed your issue ^^
Please close this topic by choosing Select as Best
/Alexandre
