2024-07-15 10:02 PM - edited 2024-07-15 10:13 PM
STM32U585xx SBSFU source code examples do not build properly.
Nice to meet you.
If you download and check the en.stm32cubeu5-v1-6-0.zip file (including patch), it contains an example for STM32U585 SBSFU.
If you try to build the 'SBSFU' example for 'B-U585I-IOT02A' board according to the instructions in readme.html, it does not build properly and 'Build failed' occurs, and even if it is built properly, 'SBSFU_Appli\Binary\sbsfu_app.bin' ', etc. are not created.
I would like to solve the problem for some reason, so please give me some advice.
Example source: Refer to STM32Cube_FW_U5_V1.6.0/Projects/B-U585I-IOT02A/Applications/SBSFU/readme.html.
Tools: IAR EWARM 9.50.1
situation :
'SBSFU_Appli\Binary\sbsfu_app.bin' not created.
'SBSFU_Appli\Binary\sbsfu_app_init.bin' not created.
'SBSFU_Appli\Binary\sbsfu_app_enc_sign.bin' not created.
'SBSFU_Appli\Binary\sbsfu_app_sign.bin' not created.
'SBSFU_Loader Non Secure Project' Build failed.
We are unable to proceed because this issue has not been resolved.
Please help.
thank you
2024-08-19 06:48 AM
Hi @Debugger
There is a known limitation when your path contains spaces:
Can you please double check if your path doesn't contain spaces ?
On my side, I built the projects as described in the Readme w/o any issues.
best regards
