NVIC_EnableIRQ causes Hardfault when called from SFU_BOOT_RunSecureBootService
Grogu
Device - STM32H7B3I-DK
SBSFU base Project - STM32H7B3I-DK\Applications\2_Images_ExtFlash
I are using a different flash chip than STM32H7B3I-DK has MX25LM51245G and I am using MX25L51245G
1) I have implemented the flash driver and test with standalone project its working as expected.
2) Tested the code with Images_SBSFU project before beginning of secure code
#if 1
  // Test the OCTO flash driver
  uint32_t buf_len          = 0x100;
  uint32_t start_address   = EXTERNAL_FLASH_ADDRESS + 0x20000;
  uint8_t spibuffer[buf_len];
  uint8_t spibuffer_read[buf_len];
  volatile uint8_t *flash_area_mm = (uint8_t *) (start_address);
  for(int i =0; i < buf_len; i++) {
	  spibuffer[i] = i;
	  spibuffer_read[i] = 0xAA;
  SFU_LL_FLASH_EXT_Init();
  SFU_FLASH_StatusTypeDef *pFlashStatus = NULL;
  if( SFU_LL_FLASH_EXT_Erase_Size(pFlashStatus, (uint8_t*)start_address, buf_len) == SFU_SUCCESS) {
	  if (SFU_LL_FLASH_EXT_Write( pFlashStatus, (uint8_t*)start_address, (uint8_t*)spibuffer, buf_len) == SFU_SUCCESS) {
		  if (SFU_LL_FLASH_EXT_Read((uint8_t*)spibuffer_read, (uint8_t*)start_address, buf_len) == SFU_SUCCESS) {
				  printf("\r\n FLASH OPERATION COMPLETE \r\n");
  if (memcmp(spibuffer, spibuffer_read, buf_len)) {
	  printf("\r\n FLASH TEST FAILED \r\n");
  } else {
	  printf("\r\n FLASH TEST PASSED \r\n");
#endif
  /* Launch the Bootloader----------------------------------------------------*/
   * This is the beginning of the secure part:
   * security mechanisms will be enabled.
   * The function below should not return (unless a critical failure is encountered).
  (void)SFU_BOOT_RunSecureBootService(); /* no need to take care of the returned value as we reboot in all cases */
  /* Security or SecureBoot initialization failure. Force a System Reset */
  SFU_BOOT_ForceReboot();
Problem :
In SFU_LL_FLASH_EXT_Write which Enables ISR   __NVIC_EnableIRQ( OCTOSPI1_IRQn ) immediately causes HardFault_Handler
Thread #1 [main] 1 [core: 0] (Suspended : Breakpoint)
	OCTOSPIWriteFlash() at OSPIDriver.c:698 0x800a392
	BSP_OSPI_NOR_Write() at stm32h7b3i_discovery_ospi.c:325 0x800a67c
	SFU_LL_FLASH_EXT_Write() at sfu_low_level_flash_ext.c:111 0x8009484
	SFU_LL_FLASH_Write() at sfu_low_level_flash.c:84 0x80093a2
	WriteTrailerHeader() at sfu_fwimg_no_swap.c:75 0x8008ce2
	InstallNewVersion() at sfu_fwimg_no_swap.c:647 0x8008d9a
	SFU_IMG_TriggerImageInstallation() at sfu_fwimg_no_swap.c:880 0x8008fe6
	SFU_BOOT_SM_InstallNewUserFw() at sfu_boot.c:900 0x8007c60
	SFU_BOOT_SM_Run() at sfu_boot.c:431 0x80079c8
	SFU_BOOT_RunSecureBootService() at sfu_boot.c:202 0x8007a1c
	<...more frames...>
Any pointer here would be helpful.
Thanks in advance!
5 REPLIES 5
Grogu
@Jocelyn RICARD​ have you seen an issue something like this before?
Jocelyn RICARD
Hello @Community member​
I understand you have replaced the MX25LM51245G driver in stm32h7b3i_discovery_ospi $by your own driver.
This is working fine in standalone and at beginning of SBSFU but crash when used inside SBSFU.
This is strange indeed.
You say "In SFU_LL_FLASH_EXT_Write which Enables ISR  __NVIC_EnableIRQ( OCTOSPI1_IRQn ) immediately causes HardFault_Handler". Are you sure about this ? Is this something you have added ?
Is MPU activated in your setup ?
Did you try adding a breakpoint in the IRQ Handler ?
Best regards
Jocelyn
All the security settings are disabled soon as I call _NVIC_EnableIRQ( OCTOSPI1_IRQn ) it's in hardfault handler. I stepped in assembly as well
Hi @Community member​ ,
OK Thank you.
Well I would first try to get the hardfault details in the Cortex fault status registers to try to locate the issue.
I would check the interrupt stack pointer before activating interrupt and check
Best regards
Jocelyn
Grogu
Thanks will continue debug process and update progress.
