2021-06-02 06:05 AM
Hi all, I am trying to make an own private key on the SBSFU, if anyone has succeeded in this could you pass me the steps which I have to proceed with.
I went through An5056, then I tried to change ECCkey1 but in some cases. it works and it is upgrading with the previous key generated firmware without any issues. in general, this cannot happen. it should reject while installing since it has 2 different keys. So can anyone tell me where I have gone wrong?
2021-06-03 02:56 AM
Hello Roshan,
Here are 2 possible solutions:
1 Using openssl
The curve used in SBSFU is prime256v1
You can get this information for instance by typing:
openssl ec -in ECCKEY1.txt -noout -text
Private-Key: (256 bit)
priv:
81:28:6e:70:04:2a:1f:76:9a:f4:84:f9:7e:f4:85:
03:2f:15:bf:0b:3a:0f:93:18:1f:43:aa:ee:1d:ca:
f3:bc
pub:
04:ba:f2:97:f8:3e:e3:07:dc:16:c3:71:78:1d:f1:
b0:3e:f0:95:b0:44:54:12:81:48:fb:2c:66:b9:54:
3d:a5:4a:e8:26:04:76:b7:37:8b:3c:46:d8:fd:6a:
63:61:7c:46:c3:7d:e9:46:44:31:6e:d7:e1:6d:ba:
70:ed:44:ba:02
ASN1 OID: prime256v1
NIST CURVE: P-256
read EC key
Openssl provides a way to generate a key for this curve:
openssl ecparam -name prime256v1 -genkey -noout -out NewECCKey.pem
Then just rename this NewECCKey.pem in ECCKEY1.txt to replace the one provided in the package.
2- Second possibility: Using provided prepare_image tool (located in Middlewares\ST\STM32_Secure_Engine\Utilities\KeysAndImages\win)
Just type command:
prepareimage keygen -k NewECCKey.pem -t ecdsa-p256
Best regards
Jocelyn
2021-06-03 02:56 AM
Hello Roshan,
1 Using openssl
priv:
f3:bc
pub:
70:ed:44:ba:02
NIST CURVE: P-256
read EC key
Just type command:
Best regards
Jocelyn
