WUF flag when exiting Standby
‎2023-06-05 3:12 AM
Hello.
STM32G070C
I'm having some issues with the WUF flag when exiting Standby. Exit mode is set to WKUP1 (PA0).
I poll the register after exiting standby and in the PWR->SR1 register, the SBF flag is set, but the WUF1 flag is cleared.
I also noticed an error in RM0454 Rev 5, on page 103 in the description of exiting the mode, it says that the SBF flag is in the PWR-> CR3 register, but it is in the SR1 register.
Code example.
void sleep()
RCC->APBENR1 |= RCC_APBENR1_PWREN ;
PWR->CR3 = 0x8001;
PWR->CR4 = 0x1;
PWR->CR1 &=~ PWR_CR1_LPMS_Msk;
PWR->CR1 |= 1 | (1 << 1);
PWR->SCR = PWR_SCR_CSBF | PWR_SCR_CWUF1;
SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
__SEV();
__WFE();
asm("nop");
__WFE();
asm("nop");
int main()
ClockInit();
_delay_init();
if((PWR->SR1 & (PWR_SR1_SBF)) != 0)
// I get here
if((PWR->SR1& (PWR_SR1_WUF1)) != 0)
// I don't get here
- Labels:
Power
STM32G0 Series
‎2023-06-06 10:34 AM
I figured out the problem today, but did not have time to write here. The problem was that I was parsing the debug data incorrectly. The WUF1 flag is set. I also checked WUF2, this is also set.
thanks for support.
‎2023-06-06 9:49 AM
Hello @Community member​,
Are you sure that you're exiting standby mode?
SBF is set which means the device entered standby mode but WUF is cleared means probably you didn't exit the standby mode.
A power-on reset occurs when exiting from standby, all registers [except the ones in the backup domain] are reset, this includes the PWR_SR1 register. The WUF1 flag is only set after exiting standby modes.
>> Thank you for reporting the typo, it is tracked internally with ticket number: 154097 (This is an internal tracking number and is not accessible or usable by customers).
thanks for support.
‎2023-06-06 1:37 PM
